correct fuel pressure for 396. bbc 7 1/2 to much?
lsbw17
weatherford , tx
Im having a problem with my carb runnin rich ive changed the jets to
76 in front 86 in the rear this is a mighty demon 750 dp. Im runnin 7 1/2 lbs of fuel pressure
It seam to load up an run rich at idle but pulls every where else. I have my primary an
Secondary air bleeds set at 3/4 turn out an transfer slots are barely exposed just a square is showing in the bore . . . I have 10 lbs of vaccum at idle an a 6.5 power valve ..... do I back the fuel pressure of a bit? ? ? Any ones advice would be nice
Thanks larry
alex383
369
douglas az
Thanks larry
i use a 9psi behind my 850 proform whit blue holley whit 0 problems ;)
lsbw17
weatherford , tx
Lol thats about right man . . It runs good at wot but runs rich enough to burn eyes. I dont think it has as much throttle response as it should
Ed Cannon
1,682
Johnson City Tn
Main jets do not effect idle. Check your float levels. Check for raw fuel dripping into the carb while running. Make sure to properly adjust the idle mixture screws. Turn them about 1/4 turn at a time one at a time.
10secBu
4,284
Westminster, MD
Fuel pressure will not affect idle mixture IMO.
Sounds like you need to go over the basic setup from square one.
Properly set the throttle blade position so the transfer slots aren't exposed too much. Set primary & secondary blades equally.
Set baseline idle mixture screws at 1 1/2 turns out from lightly seated.
I set idle mixture screws for the highest rpm idle in gear, then back down the throttle blade position to achieve target idle rpm.
Ideally when the carb is correct, the engine should restart (when fully warm) without needing to touch the gas pedal. If you have to pump the pedal a little to get it to start the idle is lean, if you have to hold the pedal open to start it's too rich.
Again, when checking idle quality & rpm, it needs to be done in gear. Make a change to the carb, climb in the car, hold the brake and put it in gear to check how it idles in gear. If it stalls the idle is likely lean.
lsbw17
weatherford , tx
Thanks guys sorry I just replyed . . . Havent been on in a while . . . I since then got it to idle perfect an throttle response is great . . Went to a 5.5 power valve an made small adjustment s
My secondarys where opening way to fast also . .some body tweaked the arm so the primarys an secondarys where both opeing around 2000 rpm . .thanks guys
