Board index » TECHNICAL » Power Adders
Post new topic Reply to topic  [ 14 posts ]
 Post Posted: Mon Jan 09, 2012 7:20 pm
i have a 496 bbc 11.5.1 compression 1050 dominator and a brodix hv2001 intake was looking at buying a 2 inch spacer from jegs , ive heard they add horsepower is this true ? here a link to the spacer im loooking at
http://www.jegs.com/i/JEGS+Performance+ ... 7/10002/-1
http://www.jegs.com/i/JEGS+Performance+ ... 3/10002/-1
" IF YOU AINT FIRST YOUR LAST "
 Post Posted: Mon Jan 09, 2012 8:13 pm
Four hole spacers usually improve torque while open spacers can improve higher rpm performance. Some motors like them, some don't mind one way or another. The only way to know is to try it with and without either on the track or the dyno.
79 Malibu, 355cid, stock block and crankshaft, iron heads, Bullet cam, CSU E-85 blow thru, TH400 w PTC converter, BTE brake, Astro Van driveshaft, 10 bolt, 3.08 gears, 3680 lbs:
6.20@114 mph, 1.46 60'
9.70@143 mph, 1.54 60'
'86 Oldsmobile Cutlass Salon 442 - 10.35 @ 68
'70 Cutlass S - 25k miles bone stock
'70 Cutlass S - high compression 350 SBO, Crane 280 cam, 425 heads, 3.90 gears
Don't ask me...people keep telling me I'm doing it wrong.
 Post Posted: Sun Feb 17, 2013 12:25 pm
Your best gain will be from using a HVH Super Sucker. Worth about 1 to 2 tenths.
 Post Posted: Sun Feb 17, 2013 6:37 pm
http://www.highvelocityheads.com/ss.htm
whats the difference between the plastic and aluminum ?
 Post Posted: Mon Feb 18, 2013 6:30 pm
Pro Moderator
Plastic stop heat transfer to the carb body a little better.
I will say this much - I've never put on a carb spacer and lost ET.
Don't leave home without your Umbrella
 Post Posted: Mon Feb 18, 2013 11:32 pm
Ok because ive seen somewere that it says one is for street one for track .
 Post Posted: Tue Feb 19, 2013 6:35 am
I have a HVH Super Sucker works very well on my 406 pick up a 1 tenth
 Post Posted: Sat Feb 23, 2013 11:31 am
i have a super sucker on my 565.....I have no idea if it makes any power
but it looks cool
I am a dealer for TRZ Motorsports ,PM me for your suspension needs....
We'll get you hooked up
 Post Posted: Tue Mar 26, 2013 6:58 am
LMAO...........
Good spacer but far from anything but a few HP gain
 Post Posted: Fri Mar 29, 2013 6:59 pm
X2. I've seen claims of anything from .10-.40 improvements, but have never actually seen much more than a tenth in back-to-back track testing. Testing or dyno work is the only true way to find out what spacer your engine combo will like...
 Post Posted: Fri Mar 29, 2013 9:08 pm
Got an hvh super sucker on mine too. Bought a new aluminum one since when I built my new motor I found the inside of the plastic one was hangin on by a thread (cpl of lil flash fires from alky tryin to start my burnout without enough heat in the motor) didn't know it at the time bcuz alky burns clear. I suggest the aluminum one for the possibility of what almost happened to me could happen to anyone. Gas or alky! As for benefits- I have no clue cuz I've never ran without it but like "excelerater" said- it does look cool! Lol! And as "supe" said-he's never put one on and lost E.T
383 flat top sbc on alky
M/T drag radials
Come n get it!
 Post Posted: Sun Jul 14, 2013 2:36 pm
sheer plate
 Post Posted: Sun Jul 14, 2013 3:44 pm
Whats the difference between them ?
 Post Posted: Thu Sep 10, 2015 9:55 am
Newbie
Grcrygtr44 thnx for the insight would of never of thought of it until it was prb to late
cron
