Board index » TECHNICAL » Power Adders
Post new topic Reply to topic  [ 4 posts ]
 Post subject: 327 Build Questions
 Post Posted: Mon Nov 07, 2011 12:53 am
I am going to finally build a motor for my 83' Elco. Now I know its not everyones first choice but I have had this block since my father has passed so I am really not looking to build anything else.
65' small journal 327... block is currently bored to .040 over so she will be bumped to .060. I also have the forged crank that came along with her. Now I am not building a drag car... but my plans are for a Pro Charged street car.
ProCharger says that a 8.5:1 to 9.0:1 works best on running engines with 8-10 PSI of boost. I had recently purchased a rebuild kit with forged pistons running 9.07:1. I have a NIB Performer RPM intake that I am hoping will work with this application. I am looking into the ProCharger P-1SC or the D-1SC for my options.
Now for the questions.....
1. Pro Charger claims that a cam using 112-114 degree lobe separation and exhaust duration 10-12 greater than intake duration is optimum. What cam would be recommended using this setup?
2. Heads.. I have a set of 65' Camel humps. Is it even worth the time and expense it will cost to build these?
 Post subject: Re: 327 Build Questions
 Post Posted: Mon Nov 07, 2011 1:26 pm
go with a comp cam nitrous cam and get a good set of flowing heads.
350 .060 over
dart pro 1's
B&M 162 blower
750 demon
turbo 350 3500 stall
12 bolt 456 gears
 Post Posted: Tue Nov 08, 2011 5:02 pm
Money is well spent on custom stick. Look at a hyd roller at min. The roller will allow much better lobes and not be limited by the lifter design. If you looking at more rpm a a solid roller would be the correct direction.
There are many much better head out there. Use the money from the camels to buy a good set of heads.
CDR Performance
The Custom Engine Shop
Official Sponsor of the first Annual
YellowBullet.com Nationals
 Post Posted: Thu Nov 17, 2011 10:37 pm
I'd look into a good set of heads such as dart pro 1s or something of that nature. Call the cam company of your choice and tell them what you are building and have one custom ground. You'll be glad you did.
78 Pontiac LeMans
Malibu front clip
Junk motor junk trans......
