Board index » TECHNICAL » Power Adders
Post new topic Reply to topic  [ 9 posts ]
 Post Posted: Thu Apr 28, 2011 8:41 pm
I no a few guys out my way do they stall it on on the t brake and hit the spray while the lights drop get extra stall out of the conv and launch hard lol, i was thinking about this way or maybe wiring it in to come on when the t brake releases pros and cons to each?
80 malibu 11.40 at 119.1 mph on e85 10.92 at 126mph spinning the tires on a 140shot
98 z28 ls1 6 speed all stock 13.7 with 200kmiles
 Post Posted: Sat Apr 30, 2011 11:54 am
I have a friend that did that by accident in his pro-street BBC vega. He was playing with his RPM modules or full throttle switch. The nitrous activated while he was on the trans brake. He did a huge wheel stand then the car fell and broke his oil pan and bent some of his front suspension parts.
brian
What does it profit a man if he gains the whole world and loses is own soul?
http://therocketshop.blogspot.com/
 Post Posted: Wed May 11, 2011 10:19 pm
that just sounds like a bad idea- depending on the shot it can cause alot of tranny heat real quick. also if the rev limiter isnt set high enough it could cause a nasty backfire. id find a different way of getting the stall i wanted from the converter. what kinda fuel pump do you have? if its mechanical are you gonna have enough volume to maintain the pressure at launch rpm? mabe im over paranoid but i dont get away with stuff like that it, Id end up burning something or putting my carb into the atmosphere.
 Post Posted: Sat May 14, 2011 4:15 pm
Pro Moderator
No, never!
Kevin 78 Cutlass
KSR Performance & Fabrication
352-225-1210
http://www.InHisWakes.com http://www.TRZMotorsports.com
 Post Posted: Mon May 16, 2011 12:01 am
after thinking about it i figured out it was really not a good way of doing things the few guys that do it out there it seems to work for but thats them lol. i wired it up so either it will come on with the release of the trans brake or i can over ride that with a switch.
 Post Posted: Mon May 16, 2011 8:20 am
your engine will thank you!
 Post Posted: Thu May 19, 2011 7:41 pm
#### NO !
I HAVE HOWEVER AS SOON AS I LET GO OF THE TRANSBRAKE BUTTON THE NOS DOES ACTIVATE PROGRESSIVLEY
JUST YOUR AVERAGE BENCH SEAT COLUMN SHIFTED 10 SECOND SMALL BLOCK !
79 Chevy Malibu Classic w/ 27 k orig miles sbc th350 present project
78 Pontiac Lemans SBC TH 350 10 bolt street car ...sold
79 Pontiac Grand Lemans SBC TH350 real ugly and real slow ...sold
70 Chevy Camaro 11.5.1 355ci M-22 12 bolt 4:30's ....sold
 Post Posted: Mon Oct 24, 2011 9:14 pm
I have done both ways.
We have set a few cars up using one set of solenoids to perform two functions (turbo car.) The last car I did was pretty trick...
-When you pull up to the lights and stage, there are two arming switches that need to be in the "on" position.
-One switch activated the nitrous when it saw WOT, and transbrake input, but it was set on an RPM window switch so it dropped out 200rpm before the chip (we did this to spool a fairly large turbo on a 6 cylinder)
-The second switch would turn the nitrous back on when the transbrake was released, and still saw WOT, bypassing the window switch and running the spray down the big end.
We have been running this setup on the car for two seasons and haven't hurt the trans/ converter yet to speak of. Its a quick and easy way of killing two birds with one stone using the same pair of solenoids!
 Post Posted: Fri Nov 04, 2011 7:24 pm
I know turbo guys do it, the ones with small engines and huge turbos. Dont know of any N/A guys doing it.
434 BBC, TWIN TURBO, 9.24@151.66 1/4, 5.87@121.37 1/8th STREET CAR, drag radials, full exhaust with tailpipes!!
http://www.youtube.com/watch?v=i5dWr5aE ... detailpage
http://www.youtube.com/watch?feature=pl ... OMKYtv1zC0
