Test Pipes for removing Cat
Do they still make these, to check out if you cat is clogged? Er they replace the cat.
Trickbu
T5MalibuWagon
1,386
Fort Worthless TEXAS!
you might try pypes I think they have one, "to check if your cat is clogged" LOL
malibu101
441
Walnutport PA
I haven't seen "test pipes" in years.
However I have seen kits to install "generic converters. What I've seen was a generic convertor that is just a straight pipe WITH a convertor and then you buy a kit that contains the proper size, shape, and bend fitting for each end.
Don't buy the generic convertor JUST but the mounting kit for it ;)
80ECLT
3,927
Sheboygan Falls, Wisconsin
Make your own "test Pipe" LOL!
In the past, I have taken a used cat off, welded the next size smaller pipe inside, and have gone through the sniffer w/o a problem.
I don't really need to have a cat as there are no testing here.
I just want it outta there. Plus it's probably useless anyhow.
Trickbu
