Board index » TECHNICAL » V6 Tech
Post new topic Reply to topic  [ 14 posts ]
 Post Posted: Sat Dec 10, 2011 10:48 am
I have a question that I'm hoping someone here might be able to answer. Does anyone here know if there is an emission compatible 4 barrel intake manifold available for the 229/4.3 V6? I've looked at an Edelbrock catalog, and through GM performance parts as well, and while they do carry 90 degree 4 barrel intake manifolds, they're not set up for EGR, and other emission equipment. I know that GM built some 4.3 V6s in the mid '80s with 4 barrel carbs for use in light duty trucks (and they would have had emission equipment on them), are they the only ones? I have an idea for an engine build, that's carbureted, but being as how I'm in Ontario, it will have to be smog legal. Any and all help is appreciated, thanks.
 Post Posted: Tue Dec 13, 2011 6:42 pm
Anyone?
 Post Posted: Mon Dec 19, 2011 9:28 pm
I ran into a 79 200 V-6 with a rockchester 4 barrel,, factory intake and if I remember right it had a EGR valve on it,, I will stop by and see if they will sell it,, Matty man
matty man..malibu fan
 Post Posted: Mon Dec 19, 2011 9:32 pm
What was the original application?
 Post Posted: Tue Dec 20, 2011 8:50 am
T5, who are you asking? I have an '81 Malibu with the 229/2 barrel, and I'm thinking about a carbed 4.3 swap. I know that GM used a carbed 4.3 in '85 & '86 on light duty pickups and Astro vans, just trying to see if anyone else knows of an emission compatible 90 degree V6 4 barrel intake.
Matty, I thought that the 200 V6 was a 2 barrel engine.
Thanks for your help guys.
 Post Posted: Tue Dec 20, 2011 9:41 am
1978-1978 was 200 ci; in 1979 it was 229 ci.
I haven't seen a 200 with a 4V, at least not factory offered. The 4.3 intake may be the only offering.
 Post Posted: Wed Dec 21, 2011 11:52 am
A long time ago I ran a Holley 300-34 intake with the matching 0-9694 carb on a 79 200 V-6. I think they no longer produce the intake, not sure of the carb. I don't recall if it had EGR provisions or not.
Sorry this does not really help answer your question but it's all I know.
 Post Posted: Wed Dec 21, 2011 9:11 pm
OK, thanks for your help.
 Post Posted: Thu Dec 22, 2011 12:12 pm
I checked the Holley website, and there are no V6 intake manifolds listed, just V8 parts.
 Post Posted: Fri Dec 23, 2011 9:42 pm
I will check,, the intake looked factory with a Q-jet,, the guy moved the Camino but I think I can find it and I will take pics,, Matty man
 Post Posted: Sat Dec 24, 2011 9:19 am
Thanks very much.
 Post Posted: Fri Mar 09, 2012 10:15 pm
clean,, the el Camino is gone,, the guys who had it, Snow Avaition lost thier hangar and they are gone,, their C-130 is out on the ramp,, but sorry i did not get any pics of that V-6 manifold,, Matty man
 Post Posted: Thu Jun 07, 2012 9:44 pm
I know its an old thread, but I did manage to find an original GM 4 barrel intake for a 4.3, with the EGR provision on it. I also picked up the HEI distributor, tubular exhaust manifolds, a Quadrajet for a 305, and a couple of other parts that will alow me to build an emission compatible 4.3 for the '81 Iraqi Malibu. The intake is a heavy iron piece, but its what I was looking for.
 Post Posted: Fri Jun 08, 2012 11:28 am
Ok, then the 1985 Astro/Full Sized PU 4bbl intake has an EGR setup. That would be good to know if we ever get smog checks in Kansas.
"All middle aged men are pigs," Porco Rosso
Darwin, a 1979 Malibu Wagon with a 3 speed Manual box and 2.41 gears in back
Engine is a '85 4.3 V6 topped by an Edelbrock Performer and a 465cfm Holley 4160. The heads have a 3 angle valve job and the cam is a Crower Level 1 240HDP grind with Comp Magnum 1.52/1.60 rocker arms. Full headers with 1 1/2 primaries dump into duals with 2 1/2 tubes and turbomufflers.
cron
