Board index » TECHNICAL » V6 Tech
Post new topic Reply to topic  [ 2 posts ]
 Post Posted: Sat Dec 11, 2010 8:44 pm
Question for 4.3 gods!! 1996 spider injection system, the fuel and return line (Metal) at the metering body, O ring replacement,
The insert the lines fit into are they threaded in or are they pressed in? :roll:
I need to replace the O rings under the fittings (inserts)
All help appreciated.
Thanks, Jeff
Work in progress...
With no end in sight!!!
 Post Posted: Tue Dec 14, 2010 11:48 am
For those interested the inserts that hold the O rings in the metering body are pressed in. \:D/
Work in progress...
