My next engine combo???
MalibuRacing
3,465
www.maliburacing.com
I think it has been brought up before, but I guess I'm slow. :roll: Have you guys read or checked out the L92 heads for LSx motors? 15-degree aluminum small-block cylinder heads that flow 320 cfm for about a $1000 complete including offset rockers and stronger springs. You could build a pump gas SBC making 600 hp without breaking a sweat. Just think about the potential of a turbo/EFI setup! Wonder what kind of HP the "stock" 6.0 cast iron block can handle?
Here's a good article with a "junkyard" 6.0 LSx motor with cam swap and carb setup: http://www.carcraft.com/techarticles/ccrp_0705_chevrolet_ls2_l92_cylinder_heads/index.html
GreenDragginBu
6,293
N.E. Ohio
Good article there...and Myself also as of late have been contemplating..doing this swap down the road...into something... :)
GreenDragginBu
6,293
N.E. Ohio
after some searching... :) there is a 32k mile LQ9 in MO for $1250..
from my understanding they have a 10:1 compression ratio.
Robert1320
That is an easy one.
You need a good rods and pistons.
Nitride the crank.
And a single 80+mm large turbo.
With this set-up and an iron block you
can eclipse the 1K without a problem.
And drive it every day.
The only issue is the stock LS-x based
motors are lacking head bolts.
Only 4 per cylinder!
If you really want more than 1k get the
GMPP LSX block with the extra block holes.
basketcase
9,600
Stockton, CA
www.jackstandracing.com
Nitride the crank.
The GMPP LSX block is nice...but this is what you use when you want the best and the baddest...
http://w2wpowertrain.com/t-dartls-2.aspx
What's needed as far as electronics? This has the crank trigger system doesn't it?
Mark
455_82malibu
1,400
WISCONSIN
buy the edelbrock-msd intake ignition package and plug it in, it uses the cam and crank sensor, thats it.
I'm doing an lsx swap. I'm building my own wire harness though. and it has crank and camshaft position sensors.
