LS1 into a G-body who has done it?
454RAT
2,012
Summerville, SC
Im going to give this a shot and want to know what it takes and what things to expect. I want to install a LS1 with the overdrive trans into a wagon with A/C and all. I know it takes motor mounts and trans mount. And also a notch on the frame to clear the A/C compressor.
What about the fuel system? i would like to use a in tank pump and would like everything to work. any advice part #'s or pics would be a huge help in the planning for this. Thanks
Justahbu
1,939
Reno, NV
Crossmember:
http://www.transmissioncenter.net/gforce_double_hump_crossmembers_.htm
Heres a bunch of info:
http://www.hpsalvage.com/st.htm
cherp22
2,777
Roxana, IL
Do it! Have to have room for the kids!
454RAT
2,012
Summerville, SC
which years are the best? I seen a 99 vette engine for sale for $1800 w/40,000 miles? Also I know most of the newer ones are lfy by wire, would I need a cable throttle body?
lt4malibu
2,384
NJ
'02up ls1's use the ls6 block(better oiling system)and intake(rated at like 345hp i think). like malibu9in said, use the search on ls1tech.com tons of useful info.
