Gauges not lighting up
78elk
1,294
81
Mountain Home Id
I have an issue with the dash gauges not lighting up. This a stock set of gauges. The windshield wiper switch and the heating switch area lights up. The the seatbelt and bright light area works fine. Any ideas what I need to check?
TURNA
6,028
Socialist NY
shake the cluster and push on it see if they light up
do the lights on the switches dim when you turn the knob?
78elk
1,294
81
Mountain Home Id
Yes the lights on the switched dim. I'm getting a new printed circuit board, I'll see if that makes a difference. Thanks for your help.
78elk
1,294
81
Mountain Home Id
I put in a new printed circuit board. The lights work now. I had problems with oil pressure gauge, it fixed that too.
