Board index » TECHNICAL » Electrical/Wiring Technical
Post new topic Reply to topic  [ 2 posts ]
 Post Posted: Mon Aug 07, 2017 9:53 am
Well I did a boo boo. I was trying to wire in a new tach and eliminate some wiring hack jobs I found under the dash. While I was at it I mustve done something because the spots on the fuse box that say Ing arent working anymore. They used to work with the key on. I was pulling a wire that did nothing and it was plugged in one of those so I suspect I grounded it. I know there is a fuseable link by the starter I heard but everything else seems to be working. Wondering if there is a separate fuse for just that circuit. If any knows please lmk before I tear the whole dash apart.
BTW its a 78 Malibu
 Post Posted: Sat Aug 12, 2017 10:53 am
There are two red fusible links at the solenoid. They each feed one of two "Circuit 2" red 12 ga wires that go to the fuseblock. One feeds "batt 2 " and "batt 3" at the igntiion switch and "stop/hazard" and "accy" on the fuseblock. The other feeds "courtesy/clock" and "tail".
