Data Logging and Displays
jakes32guitar
14
Does anyone use a racepak or equivelant dash set up for gauges and replay or logging of data? I am wondering if I can get a dash display that would do wide band A/F, trans temp, drive shaft rpm, and maybe other standard readings like voltage, oil pressure, water temp, rpm, speedo, shift light ect that I could also record the info or at least replay the info to log and help dial in consitancy. Just brain storming here and wondering if anyone has info or personal experience. I don't need drive shaft rpm or even A/F or voltage on display at all times as long as I can log them.
jmali
13
I'm looking into the Racepak IQ3. Part number 250-DS-IQ3LD. The one I'm looking at is the IQ Street.
It looks like it comes with odometer, water temp & oil pressure. Things like fuel level, high beams & turn signal all come from the factory harness. The gps kit is also available to take care of the speedo. I believe you can add on a/f ratio & driveshaft rpm but they require sensor kits sold seperately.
10secBu
4,284
Westminster, MD
I use the Autometer data logger dash in my car.
