Board index » TECHNICAL » Electrical/Wiring Technical
Post new topic Reply to topic  [ 2 posts ]
 Post subject: Brake Warning Indicator
 Post Posted: Sun Apr 19, 2015 7:26 pm
I have a 1980 Malibu and I'm going to install the lokar emergency brake warning indicator switch http://www.summitracing.com/int/parts/lok-ehb-7001 and I was warning if the stock brake warning light in the dash has a 12v wire feeding at all times when the ignition key is on and uses the ground wire to complete the circuit or, has a constant ground wire going to it and has a switched 12v source when the ignition is on?
Thanks
 Post Posted: Sun Apr 19, 2015 9:23 pm
The parking brake switch completes the ground circuit.
cron
