NO POWER ON RED WIRE
islandmaninmemphis
New Member
Nov 27, 2013
There are two red wires with fusible links on them that go to the starter. the fusible links have been removed. When I connect one to battery or always hot source I get 12volts on that wire. When I connect the other to the same hot source the power drops to 2.5 and there is no power to any thing inside. Need help please thanks
It's partially grounding somewhere. I highly recommend replacing the fusible links if you don't like car fires...
Ditto... is it sparking when you connect the other wire?
