Greetings! I installed a remote starter solenoid kit and when we connected the battery, the starter turned the engine over. The ignition key was in the ignition, but the switch was off! Why did this happen and how shall I fix it?
How good a battery do you have? Is everything grounded right? You might need a battery with a higher cranking amps.CHimp66 said:I did just that. I had the starter/solenoid checked and it ran fine. After I reattached the wires per the instructions metal jumper piece on batt. bolt on starter solenoid to "s" bolt, thick gauge cable to batt. bolt, that cable to the right side of the remote solenoid, purple ignition wire to "s" terminal on the remote solenoid, red power cables and thick gauge cable from battery to the left side of the remote solenoid and turn the ignition switch, I have power because the radio comes on. However, as I continue to turn the key to crank the car, the remote solenoid clicks and the radio cuts off....but the starter does nothing.
