What size wire?
JuniorJ
I am installing a push button start on a project. What gauge wire is best to use?
Thanks.
Ed Cannon
1,682
Johnson City Tn
depends. if your using the push button to carry all the load use an 8 gauge wire. If your using a relay (thats the best way) the control wires are much smaller and the load wires should still be at least 10 gauge.
Just to be clear, you CANNOT put the type of current a starter draws through a push button switch, no matter what gauge wire you use. You MUST use the button to energize a relay. GM uses a solenoid on the starter motor energized by the key switch. If all you're doing is replacing the key switch with a button switch, G bodies used 12 gauge wire. It's circuit #6 & the wire is purple...
JuniorJ
Here is what is going on, I bought a 93 S10 blazer with a sbc, the colum is broken where the plunger rod attaches. You can turn the key on and jump/arc the starter an it will run till you turn the key off, so I just want to be able to turn the key on and push the button.
That's pretty much what I was picturing. We're thinking on the same page...
JuniorJ
Thanks for the info.
