Rear Window Defrost
MalibuChile
76
Temuco, Chile
I have a problem with the defrost beacause only work one "line" of the grid, the midle one. The others do nothing and its complicated since here in Chile we are in autum and weather its becaming really cold. I check the grid but the other lines look ok... Any help would be apreciated...
Greetings to all...
Realistically, the only thing you can do is replace the rear window. There are liquid repair kits for broken grids, but you have to know WHERE the grid is broken. Sometimes it's almost impossible to find the breaks.
MalibuChile
76
Temuco, Chile
The failure of one or maybe two lines, could affect the entire grid?.... I check the grid and find at leats two lines broken...
Change the rear window is not an option for me....
