4 ways not working correctly because of turn signal lever??
79BuOwner
158
Alright so i got most of the wiring things fixed still gotta get my steering column apart, but when i turn on my 4 ways they work but if i move the turn signal lever down, but not clicking in the drivers side rear light doesnt work then when i move the lever back up it will start working, same thing with using brake lights, the turn signal lever decides if the drivers side rear light works or not for brake lights and 4 ways and im guessing it would do it for turn signal also but that doesnt matter because it clicks in. My father, and grandfather have both looked at it, we have no clue what would be wrong. maybe the contacts in the column just need cleaned up?? i don't know can anyone help, thanks.
79BuOwner
158
Re: 4 ways not working correctly because of turn signal leve
found out the problem the contacts of the turn signals and 4 ways in the column, well the plastic that hold s all that has a crack, im guessing from someone that jammed the lever and cracked it, so were fixing it.
