140 AMP ALTERNATOR???'S
dickeymoore
818
Atlanta,Ga.
Hi,does anyone know the part number for AC Delco is a 140 amp alternator to fit a 1978 Monte Carlo with a SBC 400 engine or what GM cars will one work off with 140 amps for my 1978 Monte Carlo or where I can buy one?THANKS
mebe007
291
Eastern Virginia
ive been working on a write up over at gbody forum to upgrade the charging system to the cs style 140 amp alternator. thats the only one i am aware of. you will find all the part #'s you need there
http://www.gbodyforum.com/viewtopic.php?f=16&t=30335
grizwald
3,300
Ontario, Canada
http://www.svapowerproducts.com
i called and talked to ray, and he built me a cs 140 amp alternator for my car. i can't remember how much it was. i've heard good things about his products and tech support from others, and gave him a shot. he was great to deal with, and answered a few questions i had after the fact with no delay.
nawlins-tim
619
New Orleans, Louisiana
These are known to have the CS144 alternator that you are looking for "CS144 Alternator - you can get these from any parts store if you ask for an alternator for any of the following:
(1994-96) Buick Roadmaster 5.7L
(1993-96) Cadillac Fleetwood Brougham (RWD) 5.7L
(1993-96) Chevrolet Caprice 4.3L, 5.7L
(1995-96) Chevrolet Impala 5.7L
(1992-95) Chevrolet Lumina APV Van 3.8L
(1992-95) Oldsmobile Silhouette 3.8L
(1992-95) Pontiac Trans Sport 3.8L
and if you are going from a standard g-body alt, iether 10si or 12si, you need a si to cs adapter. its available at several places , NAPA being one and various places on the internet.
If you have a parts store that knows anything you should be able to go in and ask for an "SI to CS conversion harness" otherwise just go to the dealer and ask for:
Delco 8078/GM 12102921 if you have a volt gauge or
Delco 8077/GM 12083462 if you have an "idiot" light.
mebe007
291
Eastern Virginia
ok so check this out. this is my whole being stumped thing on my swap. ii have the alternator already. i just need the adapter harness. my car is an 80 regal limited with only the speedo, fuel and clock. i added aftermarket guages. a 350 was swapped in by my father way back in the day. but anyways im unsure of which harness i need.
Bad link, I think.
406Monte
1,019
Hubert, NC
Here is a write up for the conversion and all the steps for it.
http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=493219#Post493219
JBreu
321
Livonia. New York
I just got one of these and it's a direct fit....Went with the 1 wire hookup.http://www.ebay.com/itm/230794776146?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
