Board index » TECHNICAL » Electrical/Wiring Technical
Post new topic Reply to topic  [ 8 posts ]
 Post Posted: Wed Mar 02, 2011 6:20 pm
All wires are 10 gauge except the wire to the TEMP switch. Those are 14
DUAL ELECTRIC FANS
SINGLE ELECTRIC FAN
RatMalibu's TEMP SWITCH OVERRIDE
1980 Malibu BBC T-56 9"
1988 Monte LS under construction...
 Post Posted: Wed Mar 02, 2011 6:51 pm
just to add...if for some reason you want to manually turn the fan on you need a 2 pole switch (on/off) run one pole to the "- switch control" wire in your diagrams and run the other side to a good ground. I have mine set up that way, it's nice if you want it to keep cooling after it reaches the normal cut off temp of the temp switch (sitting in the staging lanes for example)
Matt
 Post Posted: Thu Mar 03, 2011 3:12 pm
Question.s 1, What size relay and type. 2, If a on/off switch is used what amp should the switch be. Thanks Alot for the Diagrams. Doug
1978 El camino
1981 Malibu SS
 Post Posted: Thu Mar 03, 2011 3:58 pm
Before I redid the wiring last summer I was running a pair of 30 amp relays and never had any problems. Currently I have a pair of 35 amp relays for the fans. Any quality relay should work.....i.e. not the kind you typically find at Wal-Mart...go to the junkyard and start looking under hoods a lot of the 90's vehicles had weatherproof singles under the hood that work great. As far as the switch it can be anything since it's not on the "power" side of the relay it's just used as a ground to trigger the relay in place of the temp switch so it really won't see a load at all.
Matt
 Post Posted: Wed Mar 09, 2011 10:22 am
Thanks guys.! I was actually in the middle of re-wiring my car and this was a project I wanted done for this season...!
 Post Posted: Sun Mar 13, 2011 9:25 am
What, no love for the guys with A/C? :lol:
 Post Posted: Fri Sep 16, 2011 7:36 pm
thanks for the wiring diagrams.just made my life a bit easier.
 Post Posted: Fri Sep 16, 2011 9:00 pm
Great write up.... AA+++
2016 Hyundai Veloster
TurboXS CAI
Borla Cat Back Exhaust
cron
