Board index » TECHNICAL » Electrical/Wiring Technical
 Post Posted: Mon May 22, 2017 4:53 pm
Stopping for fuel last night, had this wacky thing happen driving back to Maryland with the Malibu. Upon restart the bendix drive would not disengage from the flex plate, was just spinning the mtr, no matter what position the key was at. Luckily was able to disconnect the battery + side cable relatively quickly. Reattached cable, tried to restart and all was fine. No brunt smell of wires or heated up cables. Using factory junkyard mini starter which was initially giving no-start problems, until the solenoid was replaced. Been flawless for the last 2 years. Going to check it out tonight for anything obvious related to wiring by the starter and ign switch, before attempting a restart. Would not be surprised if the starter is now fried. it was spinning the mtr a good 3-4 minutes. Wiring, solenoid, ign switch, any have any idea or had a same mishap?
Thanks for any response.
 Post Posted: Tue May 23, 2017 6:33 am
Checking it out last evening, the wiring by both the starter and ign switched looked okay. The terminal back up and the starter still working fine. Be removing the starter this weekend, thinking that there's a solenoid problem.
 Post Posted: Wed May 24, 2017 9:05 am
Yep, I think you're on track with a solenoid issue..Good luck
Steve
80 Malibu/Ex-Landau/Rotisserie Resto
Mild 383 w/200R4-C/K Specs-C/K D5 Medium Stall Lockup
9" w/3.73's & 11" Disc
12" B-Body Spindle/Brake Swap & Rear Frame Notch
Jeep steering shaft up-grade-Narrowed & Rechromed Bumpers
17"x7"-8" TT2's w/BF Goodrich G Force Sports 225/50/4.75" BS-255/45/4" BS
Ya gotta be lost to find a place thats never been found
 Post Posted: Wed May 24, 2017 4:55 pm
Guess the solution was common knowledge. Definitely got my attention when the key was turned to "off" and the starter kept spinning.
Users browsing this forum: Google [Bot] and 1 guest
