Anyone do a-b-a testing with a tapered spacer /HVH sucker?
When I dynoed my motor, we tried different carbs/manifolds and spacers.
The best numbers we got with a 4150 on a Victor were with a 1" 4 hole spacer on top of a open 1" spacer.
Since that was my best, I picked up a 2" HVH super sucker thinking it is "equal" to the 2 stacked spacers.
Anyone done any back to back testing of the HVH or other tapered spacer vs. non-tapered?
racecar77
2,438
Crete,IL
Dynoed my 468 with HVH 1" and 2" spacers. Gained 27 hp with the 1". The 2" hurt the numbers. Was really surprised that 1" made that much difference.
James Bond
1,359
Earth
i put a 1" on mine. gained 2mph and it reduced the afr by about .6
shotgun
Thought I would share.
Just got off the phone with Dean at Nickerson Performance (they built the 4150 carb).
He uses the Canton version because of pricing and found little difference in performance.
He suggested it will only get a few HP compared to the 2 stacked.
He also said the big numbers spacer companys advertise are vs. no spacer at all.
Kinda mirrors what you guys are saying.
I have a generic 1" 4 hole tapered I will throw in the pit kit just in case I can test.
racecar77, what are the specs on your combo? Want to see if mine is similar.
racecar77
2,438
Crete,IL
468, 2-bolt mains, cast crank 10.96 C/R. Big solid roller 4-7 swap, lift is .714-.748. Old GM performance Parts aluminum heads. 850 Quick- Fuel carb. MSD, 2241 Hooker. Will run on pump gas, but I blend fuel to be safe. Heads are limiting factor in making more HP. Made 587 HP and 563 ft. lbs. on dyno. Best of 10.17 @ 132 w/ 1.40 60ft. on old tires. Should go 10.? on new slicks this year. Lee
shotgun
We are similar, at least as a PONTIAC and BBC can be.
468,************************************************Destroked 455= 440 cu in
2-bolt mains, cast crank 10.96 C/R*********************11.5.
Big solid roller 4-7 swap, lift is .714-.748*************Roller .666 the devils cam :twisted: .
Old GM performance Parts aluminum heads**********OLD E-Heads.
850 Quick- Fuel carb********************************Nickerson 4150.
MSD, 2241 Hooker*********************************Custom 2" no one makes them.
Will run on pump gas, but I blend fuel to be safe.*****End up with 110, 104 when availible
Heads are limiting factor in making more HP****************Cam& Heads 300 cfm.
Made 587 HP*****624hp and 563*****581 ft. lbs. on dyno.
Best of 10.17 @ 132 w/ 1.40 60ft. on old tires.*************10.00@131 w 1.44 60ft
Should go 10.? on new slicks this year.*******************Should go 9.8? with sub 1.4 60ft
What does it weigh? Trans? Gear?
racecar77
2,438
Crete,IL
It weighs about 2950 without me. Trans is TH400 w/reverse manual valve body and trans brake. 12 bolt rear w/spool, 4:10 gear. TRZ ARB, dbl. adj. uppers and lowers. 28x10.50 slicks.
shotgun
It weighs about 2950 without me.3250#
Trans is TH400 w/reverse manual valve body and trans brake.Ditto except 2.10 first
12 bolt rear w/spool, 4:10 gear.Again ditto
TRZ ARB,HR&Parts bar
dbl. adj. uppers and lowers.YUP
28x10.50 slicks.30x9 Radial slick
We are very ,very similar.
I looked at the dynosheets and I never tried just the 1" 4 hole.
You got me thinking ( always a BAD thing). :lol:
slimbo
4,223
www.yellowbullet.com
im gonna do a back to back in the next few weeks. im gonna do a no spacer and then spacer test. we shall see. you guys with your lightwieghts. wish my car wieghed 2900 pounds......lol
Malibu355
1,803
La Marque, Texas
You said 4-7 swap. What is that?
