cam selection
k9
1,122
CHICAGO
When you are not using a dyno,how do you know if the cam you are using should be bigger,smaller,less or more duration after you go to the track?
I know some guys have access to multiple cams but what if you dont?
Get a good software program like PipeMax. Very accurate compared to the other garbage out there.
SS402
84
Lakeland, Florida
http://www.chevyhiperformance.com/tech/engines_drivetrain/cams_heads_valvetrain/0705ch_camshaft_profiling/index.html
camquest is another great program, it's free from comp cams..
George
Goob
3,641
Indianapolis
You can play with valve lash to simulate more or less lift and duration to catch a "trend" the engine likes.
Two passes for every change, on a consistent track with similar weather conditions, and don't forget the wind.
George
"In reality, an increase in lift almost always leads to an increase in duration, because increasing lobe lift requires more distance to create the opening and closing ramps. "
I don't totally agree with that statement. It is a fairly true statement for flat tappet cams, but not rollers.
DeltaT
1,050
Nor Cal
If it's the same thing I downloaded, the Camquest stuff I found to be a cheap subset of the Desktop Dyno 2000 SW, and not very useful.
Jim
SURESHOT
5,121
LONG ISALND NEW YORK
I was reading that camquest put out b.s numbers ? dont know for sure just reading that somewhere a while back i never used it myself
bowtie81
5,008
sarnia, ontario canada
Jim
x2
