Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject:
 Post Posted: Thu Feb 16, 2006 9:13 am
Warren/Tommy, Will the the 92 Camaro calipers and rotors work with this combo. Or YOU must use 1981 Camaro. Tommy what part numbers are your rotors/calipers from?
 Post subject:
 Post Posted: Sat Feb 18, 2006 4:41 pm
You must use 1LE rotors if you want to retain the bolt pattern. 92 Camaro calipers won't fit because they use a smaller brake pad-D154 vs. D52. You can use 70-81 Camaro calipers (1/16" wider than the Caprice w/12" brakes)for the job, too. I opted to retain the 5 on 5 bolt pattern so I used regular Caprice calipers. I think the part numbers Warren used is for A-1 Cardone reman. stuff. The OEM calipers for the 1LE swap are PBR dual piston aluminum and can be adapted fairly easy to our G-bodies but the brackets for the spindle are dis-continued now. You can buy the complete loaded kit through Autozone (P4747 I think) but what good is it without the right brackets? -Jabin
Gmachinz Sales & Performance
"...updating the level of performance..."
http://www.gmachinz.com
gbody parts store
 Post subject:
 Post Posted: Mon Feb 20, 2006 12:20 pm
Lemme reprint this from the previous page.:
Here ya go:
Spindles and calipers are from 78-90 full size Caprice, Caddy, Delta 88, and Pontiac. Typically wagon, police or with HD towing package.
Brake calipers, (1)#18-4021, (1)#18-4020
Brake flex hoses, #BH36848
Brake caliper hose bolts, #483-205
Brake pads, # D52
Brake rotors, 1LE, #5994
Wheel bearings, 1LE inner, #BR6
Wheel bearings, 1LE outer, #BR3
Bearing seals, 1LE, #19753
Hub grease caps, 1LE, #13977
If you're tearing down the steering too, here's the part #s:
Tie rod, inner, 78 Malibu, #ES2034L
Tie rod, outer, 78 Malibu, #ES2033R
Centerlink, 78 Malibu, #DS909
Idler arm, 78 Malibu, #FA1013
Ball joint, lower, 78 Malibu, #FA3000
The tubular upper A-arms required should have ball joints already installed.
 Post subject:
 Post Posted: Thu May 18, 2006 8:59 pm
Dunno just how long Robert Adams has been doing his G-parts business, but he's a frequent player on Ray Buck's Elky reflector. He's a good guy and very knowledgeable. I haven't bought much from him but what I have, arrived soon enough with no problems. He's up-front and will tell you exactly what his stock and shipping times are.
Yea, though I am forced to crawl through valleys of SUVs and riceburners, I fear no evil, for torque and positraction art mine. Mine eight rods, eight pistons and tripower, they comfort me. For therein lies mine power, and glory, and salvation, forever.
 Post subject:
 Post Posted: Fri May 19, 2006 8:33 am
Has anybody experienced,after the conversion, at top end when the car is slowing down it starts to sway and waunder ? I also installed the Trick Springs.
 Post subject:
 Post Posted: Fri May 19, 2006 2:50 pm
79Elky wrote:
He's [Robert Adams] a good guy and very knowledgeable
I'll second that.
Dustin
'87 MCSS
 Post subject: Re: 1LE brakes
 Post Posted: Tue Apr 22, 2008 7:37 am
Big front brakes has always been on my list of upgrades for the Malibu and the Monte SS. The thing that gets me is that in a panic stop, with the stock setup, I can lock the front brakes with the Malibu.
The question is, does changing to the larger ID manual brake S-10 rear wheel cylinders, improve the front/rear bias to eliminate this lock-up situation? The Monte already has the S10 wheel cylinders. I guess I should try panic stopping with that to answer my own question.
 Post Posted: Tue Apr 22, 2008 7:43 am
Considering the expense of upgrading to tubular a arms, why not upgrade to an aftermarket kit? Better calipers, weight reduction etc... Just seems to make more sense in my mind to get a little more bang for your buck.
1979 Malibu Grocery Getter 1/8th mile best 6.92@97.2 mph @ 3400 lbs. 1.4529 60ft More to come, maybe a 6.8...
406 SBC-4 bolt main/5500/TH-350/4.56 12 bolt
Scat 9000 crank/Eagle 5.7 H-beam Rods/SpeedPro forged pistons/AFR 195 Eliminators
 Post Posted: Fri Apr 27, 2012 1:57 pm
great post
1987 Regal Turbo T, WE4 option - one of 1547 made, 54k original miles
1968 Chevelle 300 Deluxe, 2-door sport coupe, V8 - one of 6803 produced, all stock FOR NOW.
2007 TrailBlazerSS, 1SS - DD
2013 Toyota Highlander - wife's ride
1978 Malibu, 454 BBC, factory 4 speed - fell victim to hurricane Sandy
1973 Corvette,454,auto-matching numbers-SOLD
1968 Chevelle SS (real SS),402, auto-SOLD
2005 Pontiac GTO, 6 speed-SOLD
2008 TrailBlazer SS-SOLD (missed it, so got a replacement)
 Post Posted: Fri Sep 14, 2012 3:19 pm
keeping this alive!
1979 Chevy C30 6bt Cummins, NV4500, NP205, 25,000 mile project
1980 Malibu Classic 460 BBC, th-350 3.73 strange S60....10.91 @ 122.62
1982 Malibu Station Wagon, 355, 200-4r, 3.42 8.5, 52,000 mile daily driver
2005 Chevy Silverado 2500 HD Extended cab, short bed, 4x4, 8ft plow
BREAK S#1T RACING!
 Post Posted: Fri Sep 14, 2012 9:52 pm
Good Lord
:shock:
1978 Malibu Coupe SBC TH350
1979 Malibu Coupe LQ9 TCI 6X
 Post Posted: Tue Sep 18, 2012 7:52 pm
so the spindles need to be from a 78-90 full size with caprice or towing package to have 12 inch brakes? if i had just spindles how can i tell there for 12 inch brakes and not the regular ones they came with ? also is there anyway to tell it has 12inch brakes other than measure the rotors
 Post Posted: Tue Sep 18, 2012 8:13 pm
All you need are spindles from those years of a Caprice. Period. Doesn't have to be a wagon.
 Post Posted: Tue Sep 18, 2012 8:32 pm
i meant to say does it have to have a police or towing package sorry
 Post Posted: Tue Sep 18, 2012 8:40 pm
The 9C1 spindles are not unique?
