Post new topic Reply to topic  [ 3 posts ]
 Post Posted: Thu Oct 27, 2016 9:10 pm
I'am back in a gbody now . Not a Malibu but a Monte Carlo SS .
I'am wanting to lower the front end 1.5 to 2 inch and get a little better braking . Coil over front way later down the road , after i get a rear end ect.
I been reading about the blazer brake upgrade and if i go this route luckily a friend has a set of 2 inch blazer drop spindles a can work a trade with. i'll need to get new hubs but not a big deal. I've read the spindle push the wheel out approx 3/8 to 1/2 inch per side . But i have read conflicting things about 15 in rims not fitting or tie rod end rubbing with stock upper and lower arms .
Has either of the above been an issue if you run this setup ?
 Post Posted: Sat Dec 17, 2016 2:16 pm
Blazers came with 15" wheels so they should fit....
'78 bu, 350/310 hp, M-21. Now with a GN 3.42 rear and Detroit Tru-Trac, Xtreme rims, grey bucket seat Monte interior
 Post Posted: Thu May 11, 2017 2:34 am
I've had 15inch weld prostars, 16inch gtas and s10 extreme rims and also 17 torque thrust 2s all work with blazer brakes and spindle swaps on gbodys
