Post new topic Reply to topic  [ 2 posts ]
 Post Posted: Sat May 14, 2016 7:07 pm
Has anybody drill rotors to install 1/2 in press in studs? Reason for doing it is lug nuts I want to use seem to be available only in packs of 20. Have 1/2 in rear end.
1987 Monte Carlo aero coupe on Alky
ET to be determined
 Post Posted: Sat May 21, 2016 9:16 am
I did it back when I did my suspension with the 1LE rotors because they had 12mm studs. I do not remember what studs were used. Make sure you have the rotors turned after the rotor is drilled out and the studs are pressed.
