Post new topic Reply to topic  [ 2 posts ]
 Post subject: Anybody try this?
 Post Posted: Tue Mar 15, 2016 9:33 am
So I'm starting to gather parts but have no time. So the last thing I should do is look to gather more parts. Lol.
Ok here's what I'm thinking. I have the ls1 rear brake upgrade minus the rotors and pads. I also
Have the blazer spindles and calipers. From what I've read unless I missed something is that the ls1 rear set up is bigger than the blazer front set up? Since I hear the ls1 rears are limited to the 15s that will fit over them. Either way I'm thinking before I buy rotors and pads is there a bigger rotor I could use and make brackets to place the calipers to accommodate the bigger rotors and still use the blazer calipers? Anybody try this before. Or maybe ls1 rotors and calipers? I can make or have made brackets if I can't find them. That's the easy part I think. I'm more concerned that the parts will work together. I have 15s now but I think I'm going to step up to 17s.
Lmk your thoughts ideas or what have you tried that worked or didn't. Thanks
 Post subject: Re: Anybody try this?
 Post Posted: Tue Mar 15, 2016 9:49 am
http://www.kore3.com/index.php
1980 Malibu coupe 468/th350
cron
