Post new topic Reply to topic  [ 4 posts ]
 Post Posted: Tue Dec 15, 2015 10:58 pm
swapping to the late blazer knuckles and brakes. Is there and upgraded aluminum caliper that would replace the cast iron 2 piston caliper?
1987 Monte Carlo aero coupe on Alky
ET to be determined
 Post Posted: Fri Feb 26, 2016 5:00 am
The only ones I know of also require different/larger rotors. Check out Kore3. They make an adapter bracket that bolts in place to use C5 Corvette calipers and rotors on the Blazer spindle and hub. Mind you, these require a minimum of 17" wheel...
'78 bu, 350/310 hp, M-21. Now with a GN 3.42 rear and Detroit Tru-Trac, Xtreme rims, grey bucket seat Monte interior
 Post Posted: Sat Feb 27, 2016 3:51 pm
http://www.flynbye.com/
They may have something or be able to do something for ya.
MR.com Facebook page
'87 Fiero GT - 2.8/5-speed
 Post Posted: Sat Feb 27, 2016 8:19 pm
Kore3 does have brackets that bolt to the Blazer spindle to fit aluminum calipers. But the minimum is a 13" rotor which will require a 17" wheel. I just asked them about this actually.
