Board index » GENERAL » General Discussion
Post new topic Reply to topic  [ 3459 posts ]  Go to page Previous  1 ... 226, 227, 228, 229, 230, 231  Next
 Post Posted: Mon Sep 17, 2018 3:41 pm
When the 78 was on the rack for the transmission instillation, I seen the bottom of the rockers weren't painted. So I took the time to get both sides painted.
 Post Posted: Thu Sep 20, 2018 7:51 pm
I put the 78 on my ramps today, hope to get transmission parts on tomorrow.
 Post Posted: Fri Sep 21, 2018 7:02 pm
I put the TV cable seal in today. Hope to get the transmission mount in tomorrow.
 Post Posted: Sun Sep 23, 2018 8:35 pm
Had some problems, but got the transmission mount in today.
 Post Posted: Mon Sep 24, 2018 10:11 pm
I cut the starter hole in a new flex plate cover for the 78. The used 2004r transmission has broken screws in the top 2 holes. I'm going to try drilling them out tomorrow.
 Post Posted: Tue Sep 25, 2018 5:53 am
Took it to the last cruise in of the season. Everyone left their "mark" when leaving, including me :D
'78 bu, 350/310 hp, M-21. Now with a GN 3.42 rear and Detroit Tru-Trac, Xtreme rims, grey bucket seat Monte interior
 Post Posted: Tue Sep 25, 2018 10:28 pm
I installed the flex plate cover today. I then started it to check for leaking. No runs, no drips, and no errors.
 Post Posted: Fri Sep 28, 2018 10:36 pm
I had a leak around the radiator drain. I tighten the fitting which has Teflon tape around it.
 Post Posted: Sun Sep 30, 2018 2:49 pm
I seen that my friends forgot to put the bolts in the lower radiator fan shroud. So I found a couple and put them in. All is tight now.
 Post Posted: Sat Oct 13, 2018 7:28 pm
My wife reglued the insulation to the roof of the smugglers box.
 Post Posted: Mon Oct 15, 2018 6:20 pm
I reset the choke today. It was running too many rpms on start up.
 Post Posted: Mon Oct 15, 2018 6:22 pm
I took the Elk to a shop to change the rear gears, today.
 Post Posted: Mon Oct 15, 2018 6:56 pm
Stock 7.5"? What ratio are you going with?
 Post Posted: Tue Oct 16, 2018 11:58 am
Yes, it is a 7.5. going from 2.41 to 3.73. The gears are now in and the rear shoes are being changed.
 Post Posted: Wed Oct 17, 2018 12:30 pm
The new brake shoes are on and I brought home.
