Board index » GENERAL » General Discussion
Post new topic Reply to topic  [ 3423 posts ]  Go to page Previous  1 ... 221, 222, 223, 224, 225, 226, 227 ... 229  Next
 Post Posted: Sun Jan 07, 2018 8:19 am
I actually pulled it out of the garage and took her for a spin around the neighborhood. I bought a used Holley 3310-2 carb to replace the Demon that was not very friendly to drive. Bought a rebuild kit about 2 years ago and finally finished. I forgot what crisp throttle response was all about. Also had to install new diaphragm in the regulator from sitting so long.
81 Malibu - Frame off restoration
05 GMC Sierra Denal 6.0l AWD
Cliff C.
 Post Posted: Sun Jan 14, 2018 8:29 pm
After almost 2 years, back surgery, and a new job, I pushed the finished frame back under the car and will start lowering the body back down on it next weekend when I'm back from a business trip. Only 4 mounts on the body didn't need repair! What a royal PITA
'78 bu, 350/310 hp, M-21. Now with a GN 3.42 rear and Detroit Tru-Trac, Xtreme rims, grey bucket seat Monte interior
 Post Posted: Wed Jan 17, 2018 9:22 pm
I removed the horn pad, cleaned it, and sprayed with SEM light oak. It looks better than it did.
 Post Posted: Fri Jan 19, 2018 3:58 pm
I walked by it the other day...
-Greg...the Exhaust Guy.
I was into Malibus before they were 'cool'.
--'82 alldoor 267 Turbo/200r4/3.73LSD 'malibu5' 'worlds fastest 267 lol'
Undergoing Toyota aluminum 4L V8 swap
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
 Post Posted: Sat Jan 20, 2018 4:51 pm
Does blowing sawdust off of them count towards "working" on them, lol? I had to cut some boards yesterday and put a nice layer of sawdust on both of them in the garage. Whoops.
1978 Malibu Coupe SBC TH350
1979 Malibu Coupe LQ9 TCI 6X
 Post Posted: Sat Jan 20, 2018 5:05 pm
Just ordered tires for it. Don't even have the wheels the fit the tires but they were on clearance for $84 each for 275/35/18 so I couldn't pass it up :)
 Post Posted: Sun Jan 21, 2018 1:21 pm
I pulled the steering wheel off today. I'm cleaning to to paint with SEM light oak to match the rest of the interior. While it's off I plan to check the ignition switch.
 Post Posted: Mon Jan 22, 2018 1:13 am
jammed the toyota motor back in it and my buddy and I pushed it out and turned it around and stuffed it in the other side "cold side" of my garage. That build is on the back burner until I can bring it up to my shop to do all the heavy fab work.
put my tercel on the "work" side...since well I drive it often and that side has the electric garage door opener :lol: i'm tired of having a few extra things to do to leave and arrive. I am back to button status!
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
 Post Posted: Mon Jan 22, 2018 9:53 pm
I painted the steering wheel with SEM light oak. It looks good.
 Post Posted: Tue Jan 23, 2018 8:57 pm
Rebuilt the quadrajet carb and installed that with a new dist. Purrs like a kitten...
~wwoodley
 Post Posted: Tue Jan 23, 2018 9:16 pm
Big brown truck delivered my 4 new tires today :D now I need to save my pennies for the wheels to mount them on LOL
 Post Posted: Tue Feb 06, 2018 11:44 pm
I pulled the steering column today and hope to see what the problem is.
 Post Posted: Sat Feb 10, 2018 8:39 pm
Started taking off the dash to repair some problems. I'll give more details as I figure things out.
 Post Posted: Mon Feb 12, 2018 10:00 pm
I had problems with the E Brake handle pulling through the dash. I took a body shim and reformed it. I bent the top over and shortened the legs on it. With the handle in the dash, I slipped the shim over the back of plastic , placing it next to the back side of the dash. Now the handle won't pull out.
 Post Posted: Tue Feb 13, 2018 4:22 pm
When I put a dash cap on my dash, I had problems with getting the screws in the holder on the firewall. So while everything is loose, I drilled holes from under the dash. This got the screws in the right place and the dash is very secure. I now need to fill 2 holes in the defroster vent.
