Board index » GENERAL » General Discussion
Post new topic Reply to topic  [ 3459 posts ]  Go to page Previous  1 ... 220, 221, 222, 223, 224, 225, 226 ... 231  Next
 Post Posted: Tue Oct 17, 2017 8:49 pm
Pulled bolts out of pan and removed pan gasket. Going to remove the pan and change the rear main seal.
 Post Posted: Wed Oct 18, 2017 3:16 am
Picked this up for the Monte.......hint hint
1980 Malibu BBC T-56 9"
1986 Oldsmobile Cutlass.
 Post Posted: Thu Oct 19, 2017 9:05 pm
FINALLY fired up the wagon after about a month being apart. Not much time these days. Ran good. Set timing to 10* to get a little more out of her. Distributor looks to be rotated quite a bit, so I think she's a tooth off. Either tomorrow or the weekend, going to loosen up the clamp and move it over after confirming tdc on #1 compression. Again. UGH
1978 Malibu Coupe SBC TH350
1979 Malibu Coupe LQ9 TCI 6X
 Post Posted: Wed Oct 25, 2017 7:39 pm
I installed the Aeromotive Stealth pump in my new gas tank, ordered all the fittings and lines for the new fuel system and welded shut the old lines on the sender unit to use it as a gauge only.
87 S10 Blazer 421 18 degree SBC
16 Silverado Crew 5.3/6 speed DD
88 Monte Carlo LS 350/200 4r family driver/ cruiser
Michael
Firetruck1@aol.com
 Post Posted: Mon Oct 30, 2017 2:50 pm
I adjusted the choke today. I then checked the wot from cab compared to at the carb. I adjusted so they are the same. I had to break the sleeve due to it making it stick at wot.
 Post Posted: Sat Nov 04, 2017 6:23 pm
I put new 0 rings in the air conditioning system today.
 Post Posted: Sat Nov 04, 2017 9:10 pm
Someone came out to look at the stocker today. Thats about it
-Greg...the Exhaust Guy.
I was into Malibus before they were 'cool'.
--'82 alldoor 267 Turbo/200r4/3.73LSD 'malibu5' 'worlds fastest 267 lol'
Undergoing Toyota aluminum 4L V8 swap
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
 Post Posted: Sun Nov 05, 2017 6:14 am
Stood out in the yard and stared at the Monte wondering if it is worth fixing............. ](*,)
 Post Posted: Sun Nov 05, 2017 12:07 pm
Checked for signs of mousies. All clear...
 Post Posted: Fri Nov 10, 2017 9:14 pm
I received my new vacuum reservoir. I needed to change it by grinding some of the plastic off so it would fit. It's now installed.
 Post Posted: Thu Dec 28, 2017 8:32 pm
I took the body off my donor grand prix framer. It took about 3 hours total including running home to grab the utility and car trailer to bring both halves home. amazingly while all the body bolts zipped right out, I will have to repair about half of the body mount bolts. Im fine with that as they are easy to do and cheap. At least now my Monte will have a nice straight frame. I plan to box it, notch it and reinforce all the critical pick up points before dropping my Monte body back on it.
I also wrapped up my Holley Sniper conversion.
Michael
Firetruck1@aol.com
 Post Posted: Mon Jan 01, 2018 10:34 pm
current status...just waiting to move my shop into its new location so i can haul it over and finish the frame work and start building the mounts. I could get it done at home. But it wouldnt come out as nice and its a PITA...vs I have everything I need at my shop
--'84 Bonneville...
Past Malibus,
-79 Malibu 4dr
-79 Malibu 2dr
-80 Malibu 4dr
-79 Malibu 4dr
-83 Malibu 4dr
 Post Posted: Tue Jan 02, 2018 6:55 am
Lets see some close ups of that custom ac/heater box!!!
 Post Posted: Tue Jan 02, 2018 9:27 am
Still getting situated in my new garage/home, so it's going slow. Nice to at least have 2 of my cars under one roof! Was going to bring my wagon home, but it's been VERY cold here the past couple weeks (like lows in the NEGATIVE teens at night, with highs during the day between 0 and 6). Next nice day (at least in the 30's), I'll bring her home and snap a pic!!
 Post Posted: Wed Jan 03, 2018 11:02 am
I worked o polishing the back window. It's pretty bad, I will probably need to replace it. This a new experience, so I'll work on it for awhile.
cron
