Board index » GENERAL » General Discussion
Post new topic Reply to topic  [ 2 posts ]
 Post subject: Ignition stuck 'on'
 Post Posted: Sun Sep 02, 2018 10:07 am
Been picking at the car. Got nearly everything rewired with a painless 24 circuit keyed GM kit. Been testing circuits and had zero problems till I tried the starter. Move key to on and everything works...lights, blinkers etc. Went to crank it to test starter and I didnt have enough amps ...no big deal but now the problem is the key is stuck in the ON position. Its locked in that position. I tried the unlock tab. It did nothing. Its not against the steering lock. Is there a electrical lock in the column somewhere?
Key will move to the start position and back, thats it. I removed power and it still wont turn to off.
-Jeff-
1979 Malibu 496 TKO-600 9"
- If wishes were horses, beggars would ride -
 Post subject: Re: Ignition stuck 'on'
 Post Posted: Mon Sep 03, 2018 8:28 am
Pulled the column and just kept messing with it. Applied good pressure. Banged on the key. Whatever was stuck freed itself. Full range of motion restored.
-Jeff-
