Board index » GENERAL » General Discussion
Post new topic Reply to topic  [ 5 posts ]
 Post subject: RUST IN DISTRIBUTOR
 Post Posted: Fri Jun 08, 2018 8:45 pm
Sorry to repeat a post , but I cant locate the old one. While back we had a discussion on preventing rust inside the MSD distributor. Someone posted the name of a spray lubricant that worked wonders. My module is covered , will take it apart and try to clean tomorrow.
Nice to buy some long term solution... thanks Larry
383 stroker, forged eagle rotating assy, howards 4\7 swap cam 640/640 lift & 283/289 duration, turbo 350 with Abruzzi 4500 stall, Mark Williams 12 bolt with 4.11 spool and 35 spline axle. Trick Chassis ARB. Small tire car, 28 in. MT pro bracket radial
Best 2017 runs : 1/8 mile 1.41 6.73 @ 99.77 mph 1/4 mile TBA
 Post subject: Re: RUST IN DISTRIBUTOR
 Post Posted: Sat Jun 09, 2018 7:15 am
Google it, there are some interesting reads. I have never experienced that problem but I'm race only and it's either in the garage or a box.
 Post Posted: Sun Jun 10, 2018 4:29 pm
i had the same problem,the hardware was rusting under the cap as were the wires and cap terminals turning green.very strange.was it wire drier spray?would think for the money msd charges this wouldn't happen..
rotisserie-mod
82 el camino
406/200r4
 Post Posted: Sun Jun 10, 2018 8:50 pm
Guys at the track today all b*chin about rust & MSD boxes. Buddy gave me a kit he uses, told me to pull the module and wire brush it. Then spread the dielectric grease thin, all over. Put stainless nuts on. Try this and probably order a spare module . Plus drilling a 2nd vent hole in the cap.
 Post Posted: Fri Jun 15, 2018 5:13 pm
If you change it to the msd cap adapt number 8445 or 8420 it doesn't have rust issue like with the orignal msd cap/rotor on the msd 85551.
