Board index » GENERAL » General Discussion
Post new topic Reply to topic  [ 4 posts ]
 Post subject: 79 Malibu Fuel Lines
 Post Posted: Thu Dec 14, 2017 9:36 am
Newbie
We are installing a 383 with a holley carb and mechanical pump in a 79 Malibu. There is a 3/8 line and a smaller line coming from the tank. Is the smaller one supposed to be a return line or a vent?
Thanks!
Kevin
:D
 Post subject: Re: 79 Malibu Fuel Lines
 Post Posted: Thu Dec 14, 2017 6:46 pm
If there is a smaller one right next to it, it should be a return.
If the smaller one is on the drivers side it is a vent.
Factory V6 cars 2 lines supply and vent
Factory V8 cars 3 lines supply, return and vent.
1980 Malibu BBC T-56 9"
1986 Oldsmobile Cutlass.
 Post Posted: Fri Dec 15, 2017 3:44 pm
Newbie
Thanks for the reply. There are only 2 lines total from the tank. The smaller is on the drivers side. So must have been a factory V6 car.
So two more questions:
Do I need to run a system with a return on this V8 or is that just if I have issues with vapor lock?
Also, what would it vent into in the engine compartment? A charcoal canister?
Thanks!
Kevin
 Post Posted: Fri Dec 15, 2017 9:02 pm
Vent went to the charcoal canister
And you should be fine without a return.
