Board index » GENERAL » General Discussion
Post new topic Reply to topic  [ 8 posts ]
 Post Posted: Thu Apr 18, 2013 12:29 am
Guys, I know that mounting a front fiberglass bumper can be done several ways, but I found a simple way to mount mine, so I figured I would post it to give others some ideas.
First I had a friend that is good with fiberglass cut about 1.5 inches out of both sides of a Harwood bumper and blend it back smooth.
Then I spray can primered it and sanded it with a Scotchbright pad, then cleaned it with thinner.
I chose a can of color match paint form Advance in a color that I felt would bring the least attention to the fact that I have a glass bumper. It is a silver with a bronze tint, but the photos make it look gray. The color match paint cans have a nice fan nozzel, and I have a handle attachment that makes painting much easier.
Next I fitted the bumper so that the sides covered the gap at the fenders and I fabbed some .090 aluminum mounts by clamping the mount between the work bench and a piece of wood and bending the angles in. Notice that I did not tuck the bumper too far, again, I didnt want too much attention on the effort to lighten the car.
I used the factory holes in the frame horns and the center hole in the radiator support (I dont like making new holes unless I have to). Then I drilled the mounts and the bumper and mounted the bumper using button head bolts, small washers, and lock nuts.
Now for the top, I was stumped for a bit, but I finally decided to just use some course body screws that have a nice big washer attached under the head. They come in a small package at Advance. I simply drilled a pilot hole through the bumper and into the bottom of the header panel/grille in five locations and screwed the top of the bumper to the bottom of the header panel/grille.
It worked out well, the bumper is very secure, and this can be done with the simplest of tools.
After doing this, I have a new set of Ice Man brackets that I never used.....
Special thanks to Allen at Kolors Custom Paint in Elm City N.C. for the buddy deal on the fiberglass work!
Here are some pics......
I had a Malibu before Malibus were cool.
83 Wagoon
Its got faded paint,
baby on board signs,
and factory hub caps!
 Post Posted: Thu Apr 18, 2013 7:51 am
Yep, that's what I do. Instead of having the lower brackets mounted on the outside lip of the lower bumper.............bend the bracket so it sits "inside" of the lip. Its a much cleaner look and the brackets aren't as visible. All you need now are some bumperettes (bumper guards) !
Young Danielson ? "WAG-ON" "WAG-OFF" ! ! ! !
 Post Posted: Thu Apr 18, 2013 5:49 pm
nice post I have both a fully tucked bumper and a harwood fact. width bumper,nice work.
 Post Posted: Thu Apr 18, 2013 5:59 pm
Finally, someone showed how They did it. Besides going with a tucked glass bumper that everyone knows is fiberglass. The one you installed is the one I prefer. Bet you dropped 75lbs off the nose too. Now i'm thinking real hard!!
 Post Posted: Thu Apr 18, 2013 6:50 pm
Looks good.. Nice work...
1979 malibu
SBC
 Post Posted: Thu Apr 18, 2013 6:53 pm
Do you have any pics of how it is attached on the top side?
'80 Malibu coupe project
454BBC .030 over , ported 781's, Team G, 850dbl pumper
T56 6-speed conversion in progress
G/N 8.5 4.10 w/ Richmond locker
 Post Posted: Thu Apr 18, 2013 10:45 pm
No, its just screwed in from the top of the bumper, the bumper sits against/under the header panel/grille, and I just drilled a pilot hole and screwed the screws in....
83 Wagoon
 Post Posted: Fri Apr 19, 2013 9:16 pm
I agree, but my car is so low, you cannot see the brackets....
83 Wagoon
Users browsing this forum: Bing [Bot], cutlass-388, V8 Rumble and 1 guest
