80superbu
2,253
Colorado springs, CO
Got these in the mail today along. Also ordered a new Strange S60 w/40 spline axles and Wilwood disc brakes form TRZ
melloelky
3,654
mass
malibuguy said:
Decided to install my suspension kit that Ive only had for a year onto the turbo car...
Prior to disassembly...
awesome that's nice stuff!
nillabu
778
St. Cloud, Minnesota
Installed a new aluminum trans pan on the 200r4. Pan is from CT Powertrain Products tapped for a drain plug and temp sensor. Nice piece. Been dialing in shift points with trimmed governor weights/springs so draining it first is making it much less of a hassle. Started out with 34.5 grams & 19.5 grams on the weights. Part throttle 1-2=14 mph w/a nice chirp, 2-3=24 mph & 3-OD=34-37 mph. Stock weights were 42 & 22 grams. Haven't tried the wide open throttle yet.
malicad
1,383
South Milwaukee, WI
(Yesterday)...Drove the purple one over to my brother's house (fun drive by the way, love my new carburetor!) to hook up my Autometer Phantom tach. Over 3 hours later, still doesn't work. Frustrating. I think my tach output on my 6AL isn't working. I have another one to try to see if it isn't the tach itself. I'll figure it out. Don't wanna buy another MSD box!
melloelky
3,654
mass
hook that green tach wire to the negative side of your coil instead.
malibuguy
3,775
Finksburg, Md
Changing the carb on the stocker to the one from my other car. Stocker always had a minor hiccup on tip in...now it barely runs. Also thinking of yanking the computer controlled distributor for a regular HEI
photo.php
malicad
1,383
South Milwaukee, WI
...and fry my 6AL and/or tach. Nope. That would be the correct way for a points distributor.
thyphtmbu
202
Up in the moutian.
Pulled the Engine and Glide out over the weekend , Took the engine to have some mods.,made to it ( more power) of course , Putting the glide with the SFI approved case in, No more flex plate shield and transmission shield to contend with.
malibuguy
3,775
Finksburg, Md
Had the turbo car aligned so i can drive it now with the new suspension.
Wow why did I wait a year to install this!
