Board index » TECHNICAL » Autobody/Paint Technical
Post new topic Reply to topic  [ 3 posts ]
 Post subject: Door hinges bolts
 Post Posted: Sat Oct 10, 2015 4:55 pm
I am having trouble with the bolts that go into the A frame. The top 3 won't tighten up. What is the best way to repair, tap the hole to a larger bolts or drill and insert a threaded sleeve?
 Post subject: Re: Door hinges bolts
 Post Posted: Sat Oct 10, 2015 5:08 pm
I forgot to mention that the bolts aren't stripped.
 Post Posted: Mon Oct 12, 2015 11:17 am
I decided to drill and tap the nut, to replace with a larger bolt.
