Well its twelve bolts that hold her on. Your two radiator support bolts on each sid of radiator. Two more on upper cowl to winshield area, pretty much under the hood corners. Four more behind the doors two on each side. Not bad to get to. Then two more under rear of front fenders, you know about those you said . then all you have is the two left on each side of car in the front inner fender wells the ones thar are towards the firewall. Thats it good luck.
