Doors on Or off?
yahr
42
Brick New Jersey
Ok whats better painting the body with the doors on or off. I am thinking I can paint the car doors off and get the jambs as nice as the car. Plus I can edge the doors on a stand then paint them the fenders and header panel in one shot.
Whats the best way to get the most quality paint job?
Brown_Gbody
3,078
Milwaukee, WI
Doors off the car gives a much better appearance, but you may run into some fitment issues when putting them back on. I ran into that with an old Karmann Ghia I painted. It took a little work to get the doors to line up. But, that car had a totally different hinge design...
.02 :)
matty man
1,352
24
Grove City , Ohio
I would block and sand & prep with the doors & fenders on the car and then remove them to paint,, that way from what I am reading & watching on the boob tube it will give ya a better paint detail,, Matty man
bukweet
2,803
Mississippi Gulf Coast
Doors off, jamb it and do the inside of the doors.
Put the doors back on, align them, backtape the doors and jambs and paint it with the doors on the car.
Paint texture and color will be uniform.
How many time do you see the doors and fenders that were painted off the car come out a different color? Anything but a solid color paint and it's very possible and most likely to happen.
8)
bukweet
Brown_Gbody
3,078
Milwaukee, WI
bukweet
Yeah, I should have clarified... I painted the insides of the doors and the door jambs, and then reinstalled the doors, and shot the entire car.. Only because the guy helping me at the time said to do it that way....
I probably would have shot the whole door and then wondered why it didn't look quite right..... ](*,)
yahr
42
Brick New Jersey
8)
bukweet
Thats the answer I was really looking for. I was planning on painting the doors off the car but now I will follow that plan. I was thinking along those lines.
brunz21
152
chicago, IL
the only time you should paint the doors off is with black. any other color, especially metallics can change depending on pressure, temperature, and time in the gun. its nice not to have any tape lines, but its nicer to have matching panels.
81classic
2,833
North Port, Fl
I did not want any tape lines and painted my car with everything off the car. I painted the fenders, doors and trunk seperatly from the body. If you're limited on space or time it would be easier to paint with everything hanging on the car
