Board index » GENERAL » MalibuRacing Gallery
Post new topic Reply to topic  [ 1182 posts ]  Go to page 1, 2, 3, 4, 5 ... 79  Next
 Post Posted: Thu Nov 19, 2009 2:18 pm
[url]
    [/url]IfWell since cherp did it i think its a cool idea to post the winter progress on my projects. parts are just starting to trickle in so not much to update right now.The goal for all of this is mid tens on motor and easy 9's on the hose. plus the car will continue to be driven everywhere.
    Plans for the winter
    421
    little m block
    eagle 3.8750
    eagle 6 inch h beam
    je coated 11:1
    brodix 227cc cnc track 1 316@.650/317@.700
    comp solid roller (not sure on specs yet)
    crower hippo lifters
    brodix hv1002
    nickerson 1080 dominator
    crossmember
    cutting out the front crossmember for easy oil pan access
    headliner.
    my headliner isnt looking to good so time for a new one and also some new sunvisors.
    headers and x pipe
    hedman husler 1 7/8x3.5 headers and a torque tech 3.5 in 3 inch out x pipe. plan on welding it all up and then sending it to be coated. also plan to get the tailpipes coated.
    heres the first of the pics! my huslers showed up today! hopefully ill get over to the garage this weekend, the motor is out and already dismantled and sold off. next on the agenda is cutting the crossmember and welding in the new tubes, if i stop by the engine builder ill snap some pics of the new heads and stuff. hes basicly waiting on the pistons.
    pump gas,3880 pound,9.43@141.8 1.24 60 foot, not your grandmas gp
    2012 hot rod magazine drag week,3rd place small block power adder
    You'd give it all up for what's there for the taking
    Whatever it takes to keep your hands from shaking
    The same things you're thinking might make you feel better
    The same things that probably got you here
     Post subject: Re: Slims winter updates
     Post Posted: Thu Nov 19, 2009 2:20 pm
    Cool deal brother. I always like reading updates as the builds go along. Keep the info and pics coming. I will have some more updates this weekend. That thing is going to run!
    83 Monte Carlo SS, bbc, PTC converter, 10" tires
    1.41 9.47 145.6 shakin it down
    82 Cutlass 10.17/133 blow thru
    http://www.ultimatespeedandmachine.com/
     Post Posted: Thu Nov 19, 2009 2:25 pm
    Cool deal Cherp! cant wait to see your progress as well. Im not redoing my cage till the car runs the number! cant wait to get the engine together and on the dyno. Iwont be able to run with you big block guys on motor but thats what the bottle is for! lolol. im trying to do more with less cubes and my pockets arent deep enough for 18 degree stuff plus im trying to keep it pump gas friendly.
     Post Posted: Thu Nov 19, 2009 3:07 pm
    I thought you were gonna step up to the 227 track 1's? Those headers looks pretty dang nice, can't wait to see how the rest of the exhaust is gonna look. 8)
    You've always been taking
    And now your giving.
    Seek and Destroy
     Post Posted: Thu Nov 19, 2009 3:19 pm
    the guys at brodix said the 215 would be a better choice. the car is heavy and it needs a more midrange torque than high rpm hp. it should make more power in the shift recovery zone with the 215's than it would have with the 227's. i hope they are right. hoping for a peak of around 540+ ft pds. try to keep over 500 ft pds over a broad range to keep the car accelerating hard. its all in the combination. flow is still over 300 305@ .600-.650
     Post Posted: Thu Nov 19, 2009 7:07 pm
    I like all of your winter mods but if I could redo my old small block combo I would have went with the afr 227's with a custom cam. Those heads KILL eveerything else I have seen at the track.
    http://www.gonedragracing.com
    Best Motor Pass - 9.98 @ 135mph
    Best Spray - 5.85 @ 121mph 1/8th mile 300shot / 9.24 @ 145mph 225shot
    http://www.youtube.com/watch?v=CtoSUWhFCHA
    490bbc 13:1, NOS Bigshot, Brodix BB-2 Extra, T400, 3.90 gear, 8.5 rear, 28x10.5 ET Drags. 3485lbs.
     Post Posted: Fri Nov 20, 2009 11:46 am
    Sounds good, can't wait to see the progess, those hedman's are beautiful aren't they ? :D
     Post Posted: Sat Nov 21, 2009 7:13 pm
    This is going to be a cool thread, can't wait to watch along!
    X2 on the headers, just wish I had enough motor to need those, LOL!!!
    '79 Malibu
    6.0LS/TH400
    G/N 8.5 w/4.10 's
     Post Posted: Sat Nov 21, 2009 10:18 pm
    stopped by the engine builder today, pistons and rods are there, crank is at the balancer, block should be there this week. heres some pics. pistons look killer. very light!
     Post Posted: Sat Nov 21, 2009 11:45 pm
    Looks like Christmas has come a little a early at your place. Good luck on your new combo.
    81 Street/Strip Malibu Stock Susp. SOLD!!
    Pump Gas 406
    Column Shifted TH350 / 3800 PTC Converter
    Moser Bolt In 9 Inch / 33 Spline Axles / 4.30 Gear
    (GOING WITH GOD)
     Post Posted: Sun Nov 22, 2009 9:57 am
    looks good. I like the coating they put on the SRP's now. pretty cool
    1.51 60ft
    10.89 @121.33
    461 N/A pump gas
    1.45 60ft
    6.11 @115
    9.74@140
    461 with a Novi 2000 on E-85
    Thanks to Ultimate Speed and Machine
     Post Posted: Sun Nov 22, 2009 6:24 pm
    put in a few hours today on my crossmember. after this is done im pretty much waiting on the motor to do the exhaust. heres some pics, final pic is everthing just tacked in. ill likely put another smaller pipe towards the rear joining to the front pipe in the center.
     Post Posted: Sun Nov 22, 2009 7:06 pm
    Lookin good Pal. can't wait to get to the track this coming spring. Looks like a little weld practicing going on there on that bar tongue_nah_nah.gif
     Post Posted: Sun Nov 22, 2009 7:28 pm
    lol yeah its a borrowed welder so i was unsure on the setup.
     Post Posted: Sun Nov 22, 2009 8:49 pm
    what thickness of plate steel you using there..? :-k
    9.90's @ 132 mph weighing 3384 lbs on a little sbc motor.
