Board index » GENERAL » MalibuRacing Gallery
Post new topic Reply to topic  [ 126 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 9  Next
 Post Posted: Sun Nov 12, 2017 12:10 pm
looking good,any progress is still progress.
rotisserie-mod
82 el camino
406/200r4
 Post Posted: Sun Nov 12, 2017 12:28 pm
496 is done. Reused cam from 454. 231/238@ .050 with 600 lift on a 111 LSA. Going to try the Slick Speed Monte clutch setup. The Bdzel pedal effort was destroying the firewall. New brake lines. All kinds of new stuff. Just makes for a slow build.
-Jeff-
1979 Malibu 496 TKO-600 9"
- If wishes were horses, beggars would ride -
 Post Posted: Sun Nov 12, 2017 12:34 pm
What is the difference between the 2 pedals?
1980 Malibu BBC T-56 9"
1986 Oldsmobile Cutlass.
 Post Posted: Sun Nov 12, 2017 1:23 pm
The Bdzel pedal has a funky angle so you can use a FBody master. Worked great for years. But the firewall is beginning to crack. The Slick Speed uses a stock pedal with a new master angle that bolts up behind the brake booster. And the Slick Speed setup allows for whatever diameter master you need to get your clutch movement right.
-Jeff-
 Post Posted: Sun Nov 12, 2017 2:01 pm
Cool
I have been thinking of ditching my T56 lately and going with a 4L80E
Going to pull the BB out for a freshing up
 Post Posted: Sun Nov 12, 2017 8:07 pm
TURNA wrote:
Cool
I wish someone would snatch up the 4L80E that sits in my driveway.
-Jeff-
 Post Posted: Mon Nov 13, 2017 4:00 am
Shoot me a PM!!
 Post Posted: Tue Nov 14, 2017 8:52 pm
PM'd
-Jeff-
 Post Posted: Tue Nov 14, 2017 11:08 pm
I was thinking of going with the Sick Speed part, but I'm told the master will not clear 2241 headers...
 Post Posted: Thu Nov 16, 2017 8:22 pm
I hope that is not true cuz I have 2241s. That never occurred to me.
-Jeff-
 Post Posted: Thu Nov 16, 2017 10:36 pm
I sent Bernie (SickSPeedMonte) an email with a request for more info. I'll post his response when I get it.
 Post Posted: Sat Nov 18, 2017 1:14 pm
Bernie replied back and said the 2241s will not clear the universal master without modifying the primary tube that wraps around the steering column. He sent me pics of what someone else did, but since photobucket went crap, I can't post them.
How was your header clearance with the Bzdel pedal and the F body master cylinder? I have the McLeod 139001 original version. I guess I'll just make a firewall reinforcing plate for the master cylinder.
 Post Posted: Sat Nov 18, 2017 5:05 pm
email me the pic i can post it
 Post Posted: Sat Nov 18, 2017 8:37 pm
I had no issues with the Bdzel pedal with any configuration. And I also used a firewall reinforcing plate. Mine was not large enough. Over do the plate. Spread the pedal load. Ill beat that tube flat to make this work. I will NOT take no or 80lb pedal effort for an answer. Im stubborn
-Jeff-
 Post Posted: Sat Nov 18, 2017 10:08 pm
I better check my firewall since I have the Bdzel pedal
cron
