| Author |
Message |
10secBu
Posted: Fri Dec 10, 2010 11:00 pm |
| MalibuRacing Junkie |
Joined: Wed May 21, 2003 11:19 am Posts: 4083 Location: Westminster, MD
Hello all,
I've been putting this off a couple years now, but it's time to replace the roll cage in the Malibu. The old cage I installed back around 1995. It was .134" wall ERW mild steel with swingouts. Quite heavy, too much chassis flex and with the car running 8.50's, I was at the limit of the cage certification.
Due to the scope of this project, I expect the fabrication work to take me most of the winter. I'm working on average two evenings a week and Some on Saturday and Sunday. A job like this has taken anywhere from 200 to 250 hours to complete on average.
The new cage is going to be a 25.3 SFI certification. The car only needs a 25.5 spec, but there's not alot different other than some larger tubing sizes, so I went with 25.3 for resale value more than anything.
In addition to the cage upgrade, I'm also swapping out the 12 bolt rear for a TRZ chromoly sheetmetal 9" housing (and matching control arms). The housing will most likely be filled with Strange 40 spline gun drilled Ultra light axles & Ultra center and their Pro Race brakes. The QA1 shocks have been sold and will be replaced with Afco double adjustable coil overs.
The housing has been ordered (tubes run long, housing ends loose) and should be here in the next two weeks. Once it arrives I need to determine the length so the axles & internals can be ordered.
I sold both sets of rear wheels and will be purchasing new due to shortening the rear and going with less back spacing in the wheel.
Anyway, here's some preliminary pics showing the teardown and the progress thus far. I have the main hoop bent up and some other bars, will do the setting of those bars hopefully this weekend sometime.
10secBu
Posted: Fri Dec 10, 2010 11:09 pm |
TURNA
Posted: Fri Dec 10, 2010 11:26 pm |
Joined: Sun Jul 06, 2003 8:49 am Posts: 5389 Location: Socialist NY
WOW
_________________ 1980 Malibu BBC T-56 "The beauty of the Second Amendment is that it will not be needed until they try to take it." Thomas JeffersonEtsi ambulavero in valle umbrae mortis, non timebo malum quoniam tu mecum es
1 N O
Posted: Fri Dec 10, 2010 11:31 pm |
| Weekend Racer |
Joined: Sun Jan 25, 2004 12:49 am Posts: 70 Location: Arkansas
Thats top notch, keep us posted.
slimbo5
Posted: Sat Dec 11, 2010 3:10 am |
| Moderator |
Joined: Mon May 21, 2007 2:08 am Posts: 4029 Location: parsippany nj
Awesome work as always Todd.
_________________ pump gas,3850 pound,9.70@137 1.29 60 foot, not your grandmas gp 2012 hot rod magazine drag week,3rd place small block power adder You'd give it all up for what's there for the taking Whatever it takes to keep your hands from shaking The same things you're thinking might make you feel better The same things that probably got you here
Night Stalker
Posted: Sat Dec 11, 2010 5:54 am |
| Dragway Regular |
Joined: Tue Nov 03, 2009 10:15 am Posts: 1125 Location: Genoa,Oh
I've seen your car progress over the years and your attention to detail on your build or upgrades is a pleasure to see. I look forward to seeing the outcome of this work Todd..
_________________ 9.90's @ 132 mph weighing 3384 lbs on a little sbc motor.
Hiway
Posted: Sat Dec 11, 2010 7:49 am |
Joined: Wed Mar 09, 2005 8:29 am Posts: 3948 Location: Enola Arkansas
I agree....top notch as always. I can't imagine doing all that welding with it that close to the ground
_________________ MidsouthRacers.com
I feel bad for people who don't drink because when they wake up in the morning that is the best they will feel all day. Frank Sinatra
grand610
Posted: Sat Dec 11, 2010 9:56 am |
| Daily Driver |
Joined: Sat Dec 27, 2008 3:36 pm Posts: 42 Location: bc michigan
looks really good !!
Posted: Sat Dec 11, 2010 10:03 am |
| Moderator |
Joined: Mon Jun 02, 2003 11:15 pm Posts: 13513 Location: Oro Valley, AZ
malibuj
Posted: Sat Dec 11, 2010 10:41 am |
| Dragway Regular |
Joined: Sun May 06, 2007 9:02 pm Posts: 1065 Location: Lancaster PA
As always, Very nice work.... Looks killer....
_________________ 1979 malibu SBC
brrymnvette
Posted: Sat Dec 11, 2010 1:28 pm |
| Frequent Racer |
Joined: Mon Oct 18, 2004 2:51 pm Posts: 316 Location: St Louis, MO
Holy crap that's awesome work. Right clicking and saving pics for inspiration.
monte ss496
Posted: Sat Dec 11, 2010 1:58 pm |
| Dragway Regular |
Joined: Sun May 23, 2010 4:17 am Posts: 1359 Location: western mass
that is pretty nice stuff! we are all jealous!
_________________ "hands cant hit what the eyes cant see, float like a butterfly sting like a bee , rumble young man rumble" ------------------------------------------------------------------ 85 monte carlo ss 496 bbc th400 strange dana 60 !!!!! 79 malibu same drivetrain best pass 10.60 at 129 SOLD!
8secChevy
Posted: Sat Dec 11, 2010 2:38 pm |
| Amateur Racer |
Joined: Sat Jun 28, 2008 2:32 pm Posts: 229 Location: Williamstown, NJ
Awsome! U da man!
_________________ 370ci LS single 88mm Turbo in the works.
10secBu
Posted: Sat Dec 11, 2010 4:24 pm |
10secBu
Posted: Sat Dec 11, 2010 4:26 pm |
Thanks for the nice comments guys. Gotta try and keep plugging away at it to have any chance to be ready by spring.
