With all the questions about backspacing, I went out and measured the Malibu.
I took the idea of using a piece of aluminum angle and some 1/4-20 threaded rod from a post on this site. With two 1/2 inch holes in one end and a series of 5/16 holes in the other, it worked like a charm to find the real measurements.
On the drivers side from the drum surface to the frame was 5 3/4". From the drum surface to the wheelwell lip was 5 1/4". So the total wheel space is 11 inches on a completely stock opening. On the passenger side, it was 5 1/8" from the drum surface to the frame. It was 5 7/8" from the drum surface to the wheelwell lip. So again, there is an 11 inch opening. It looks like the rear is not centered, and sits about 3/8" of an inch to the drivers side. I guess that some adjustable control arms can fix that.
Scot
Scot
