Hoosier QTP's
tubeless works, got thm on a friends 67 camaro. works great :D
scuba_steve's_bu
440
Rock Rapids, Iowa
i just switched to hoosier full slicks. gonna run them without tubes. hopefully its ok.
red barn
628
Syracuse, NY
bigsteve said:
No tubes it is! Those tubes are just too #### heavy. Thanks
A qtp with a tube is still lighter than a drag radial. In a heavy hi-powerd car with a small tire, the tube will help the sidewall live longer.
dev1360
561
East Alton, IL
I've never run tubes untill I got these QTPs that were already mounted on my wheels. I like tubes only because I don't need to fill the tire up every few days.
TNTS79
1,252
Illiniois
I run 28x9 hoosiers without tubes, might be adding some in the future so I can lower the pressure a bit more.. Dont like to drop mine below 15 w/o tubes, if I go to tubes I think I could run 12 or 13 and not worry...
alowerlevel
395
South Jersey 08109
How much do tubes usually weigh? (I honestly have no idea). The Hoosier DRs are only 2lbs more per tire than the QTPs (275/60/15 DRs = 24lbs --- 28/11.5/15 QTPs = 22lbs) Not trying to start anything just wondering.
