Deuce4935 said:
Not trying to thread jack here, but I am definitely interested on how the tcc and brake switch are wired up. Its for this reason why I'm leaning toward going the carb route and using a 700-r4 with the lockup kit.
The TCC needs to have 12V all the time (ignition 12V). When the brake pedal is pressed, it should remove 12V to disengage the TCC. I found a simple fix by doing a search on LS1Tech.com. It is a "Stop Light Switch" from Autozone for a 96 Camaro. It has connections for 6 wires, which is for the brake lights and the TCC. Connect the normally open pins to the brake lights and the normally closed to the TCC circuit. I haven't got one yet, but plan on getting one to check out. It's only $5.99 too! I'll let you know if it works out.
Don't know if the link will work, but here it is:
http://www.autozone.com/R,1009479/vehicleId,2139502/initialAction,partProductDetail/store,53/partType,00132/shopping/partProductDetail.htm
Here's a picture:
