Decal Application Instructions
1. Mix one drop of soap into a cup of water, and use a little of this solution to dampen
(can use a spray bottle) the smooth surface you will be applying the graphics to. This will buy you a little time while you make sure it's straight.
Don't use much though!
2. If installing a windshield banner, I find it best to measure the width
of the banner and make a small mark with a pencil to indicate the center of the
decal.
3. Peel the wax paper off the back of the sticker when you are ready to apply it.
Be careful not to touch the decal lettering or contaminate it. Now lay the sticker on the surface and align it how you want it.
If installing a windshield decal, the center mark you made should be aligned to
the center of the windshield. I found the easiest way to do this is using
the "internal" antenna wires in the windshield as a guide. When it's positioned exactly how you want it, gently (but firmly) use a credit card or a squeegee to press the excess water out from underneath.
4. Let the graphics stand long enough to adhere a little, don't get in too big
of a hurry. Then GENTLY peel away the application tape that is still over the sticker. This will leave behind the individually-cut
graphics.
If you have any questions, email me at phillip@maliburacing.com
